Difference of Motion Detection and Motion Sensitivity
  • 2 Replies
  • 2605 Views
Bbprthead
Wondering if anyone can explain or define the difference between the Motion Detection settings on the actual camera settings and the Motion Sensitivity settings on the Mode Settings???
brh
@Bbprthead
The Motion Detection Test in the camera settings is simply a test to show you how to position the camera for best motion detection.
The Motion Sensitivity for the camera in the Mode section is the actual setting.
Brian
brh
@Bbprthead
Brian
Use the sensitivity setting found in the Motion Detection Test, which can't be saved since you might want to use different settings for different purposes, to create your own custom settings in your modes.
