Difference US and Europe Version?
  • 5 Replies
  • 7213 Views
CbJack68
Hello,
I'm German. My friend visit USA next month. What is the difference between US and Europe System? Can I change the Power Supply easy or it is a big problem?
best Daniel
5 REPLIES 5
IIRR, the  AC adapter takes 100-200v input, so other than the prongs being the US style you should be ok
CbJack68
Thx! so I need only another European prong and I can use the system normal?
I went and checked this morning for you.
The power supply for the PRO base ONLY takes 120v ac input.... BUT it output 12dc in coaxial plug ,center +
***( the mistake was that the Pro camera power supply takes 100-240v ac input for it's usb supply/charger )
So, you would need a 12dc supply for the base unit thake puts out a min of 1.5a, as to the cameras only a prong adapter would be needed.
Basic level of 5 cameras is supported if your upload speeds are over 1 Mbs
CbJack68
thanks for all the infos Tom, nice.
I wait here till you have check them tomorrow. then I decide 🙂
CbJack68,
Besides needing additional accessories to convert the power adapter, this could lead to warranty issues. We recommend purchasing a system locally so you have a local warranty in addition to the correct included power adapter.
