Dear Arlo Prod Mgr, Please (x100) add manual channel selection to Arlo base station.
  • 1 Reply
  • 1444 Views
wxh
I don't want to repeat the reason. Just search for `channel settings` or `channel override` in the forum you will see tons of reasons.
If you are listening to your customers, please please please, add an Advanced Settings section or something that we customer can disable auto channel selection and set it to use a specific channel.
If you want me to beg you, I will do it. Please.
steve_t
Master Master
This should go in the Ideas Exchange section except I believe it's already been posted there so please go there and find the thread and upvote it. I'm sure I upvoted it quite some time ago. I would also like this feature to be enabled
