Daylight saving not changing on cameras
  • 2 Replies
  • 2494 Views
Susie8000
I have two properties 75 kilometres apart. They both have cameras installed. In one property the time on the cameras changed automatically when daylight saving started on the other it didn’t. How do I fix please?
Susie8000
Thank you.. upon checking I have found that base station was not set to right location. I don’t know how the location changed because it was correct previously and nothing had been altered in the meantime. Thank you for your assistance.
Did you set the timezone properly for the problem base? Have you restarted it?
Susie8000
