Customized notifications
When will the customized notifications be coming to IOS?
You can currently customize notifications if you use the IFTTT application. You can receive custom notifications when motion is detected, and a low battery on a camera.
I just want to be able to change the sound of the notification not download another app that dose the same thing the arlo app does.
