Connection Failed Alert Going Live
  • 7 Replies
  • 5498 Views
  • 5 In Conversation
Rick5472
Using work PC to remote to Arlo and receiving "connection failed" when going live. I am wondering if this is a problem on my home network or work network blocking something? I did get a few motion clips while troubleshooting from work (ie restarting base).
7 REPLIES 7
Work computers are usu pretty well locked down for safety reasons and can be a problem...
If I got you right, your working via remote to your work network.... could it be a flash problem as live play requires same.
Rick5472
Would it be a flash problem if I can play other videos in my library? I see what version I hav.
No . prob not...
But going remote, your adding a whole layer of onion to the problem trying to fig out whats wrong.
Rick5472
Seems to be fine on my home PC. Must be something that my work IT folks are doing to time out the connection and causing the connection to fail. I will have to try using the app on my phone to see if that works or does the same thing next week.
Be surd to try the phone using both cell service and WiFi. It's likely that WiFi will fail but not cell service.
quanbao
I've update my Flash Player but still does not work.  I do work remote and getting the Connection Failed message when I try to view the live camera feed.  How can I fix this?  Thanks!
quanbao,
Do you get this same behavior when using a data connection on your mobile device?
