Connecting Base Station to Internet VMB4000
  • 1 Reply
  • 1742 Views
lynngalle
I have an Arlo Pro VMB4000 base station.  Unfortunately, I have had to revert to utilizing a hotspot for my internet service.  Because I'm utilizing a hotspot, I am unable to hard wire the base station with ethernet cable.  Is there another way I can connect my base station to the internet?
Dannybear
No, the base station internet connection is via the Ethernet port only.
you could purchase a wifi extender unit with Ethernet port.
you could purchase a hotspot mobile cellular Ethernet adapter from a carrier service.
After that it just gets more complicated.
what model are your cameras, they may be able to access the hotspot wifi directly without a base.
Dannybear
