I have the basic ARLO system ( uses store bought batteries ) and I want to know if the ARLO PRO add on cameras ( rechargeable battery ) is compatible and would SYNC up to the basic system.
Can I add ARLO PRO cameras to my basic system? Are they compatible?
Yes they are. No problem.
Up to 5 cameras of any mix still with free 7 day cloud recording.
Yes the Pro will work with the older base ( and the Arlo cam will work with the newer pro base)
If I add Arlo Pro camera to and existing Arlo Basic Base, would I get two-way audio as well ?
sh710,
Yes. All of the Pro Camera features will be available.
