Charging Pro Add On Camery Battery
I currently have a 4 camera original system. I want to add a single stand alone Pro camera (VMC4030) to the system. I understand this will not be a problem but I am not sure how I will charge the Pro battery. Do I have to buy a seperate special charger or is there something that comes with the stand alone camera that allows me to chsrge it pattery?
Thanks for the help
When you buy the Pro camera it should come with an adapter and cable to charge
As mentioned the separate cameras do come with a region specific charger and a Micro-USB Lead.
You will be good to go out the box
I ditched Arlo! As a Company they hold their Customers/Us in complete contempt! We beta test producs for them, the products only work properly for ~70% of the time at best!
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
