Cannot access BT Home hub after Arlo Pro setup
  • 1 Reply
  • 2793 Views
Homedad11
Just set up arlo pro, all works great but cannot access my BT Home hub anymore!
My WIFI worked fine before, but cannot find the Hub anymore. Just " Netgear and asking for password!
Any idears?
Not familiar with BT hubs but previous posters have suggested that newer versions work better. Can you access the hub's configuration?  You may be able to change channels so the router and base have different channels but a restart of the base will cause it to sync up channels again.  Your other options would be to separate the base from the router physically, moving the base several feet away (20 feet has been mentioned but less may be ok) using a long Ethernet cable or a WiFi extender with an Ethernet port.
