Can't select to record on Arlo Pro
Why can’t I select to record something on my Arlo pro? I can only watch it live; I want to be able to record whenever I want. I used to be able to do this and now that you have changed the app I can not do this anymore from my devices.
Check your modes using a browser (the app has issues with this). Make sure the proper one is selected and that the rules are set properly.
