I recently did an iOS update and my Arlo access stopped. I had to reset my Smarthub and all of my cameras, but 2 cameras still will not connect after 3 days of trying.
Hi,
Are you still experiencing this issue with onboarding your devices?
Have you tried factory resetting the cameras by "Press and hold the sync button on the the camera for about 15 seconds, until the camera LED begins blinking amber, then let go."
Can you try onboarding again via the web portal and arlo app again.
Have you tried the web portal and mobile app?
Can you try onboarding the cameras on https://my.arlo.com/#/login
You will need to sign in and then Under Devices > Scroll down to Add device > make sure to select the appropriate device for your camera.
I am having the same problem and have tried everything on the support service.
I have arlo pro 2 camera and base station. They have worked for years without a problem. 3 days ago all stopped working. All I see on my app is the old library of videos, no devices.
As suggested, I did a factor reset with the base station. That seemed to work. two green lights on left. So on and internet connected. The base hub is recognized. I hit the sync on the top of the hub and it is recognized. So my app shows my hub as a connected device.
Now I try to connect my Arlo 2 camera. Hit sync, get flashing blue and wait for minutes. It times out and the right light on the hub is not on. Camera not recognized.
Next I hold the camera sync button form 15 seconds to factor reset the camera. Tried to install the camera .. same story. I seem to be out of options. I need to get this fixed. I have a second location 100 mi away and it has the same set up and same problem. Is there phone support available .. even if I pay for it.?
Have you tried to onboard the cameras via the web portal?
Not sure how, but was able to onboard my Arlo Essential Spotlight.
But now the spotlight will not come on when motion is detected. Day or Night.
Under video,spotlight is on, night vision is on.
Tried everything but nothing works.
Is the camera recording?
