Can't connect VMB4000
  • 1 Reply
  • 801 Views
Jcajr
I have the Vmb4000 I am trying to connect it but it can’t be found on my network. Is there something I could be doing wrong? I’ve followed all the instructions to a T. I’ve reset the base also.
Is this a new or used base? What are the LEDs showing? Should be power and Internet are green and Camera may be off or solid amber. You may need to hold the reset button on the back for >10 seconds until the LEDs flash amber. Let it reboot and try again.
