Can’t activate my camera without paid subscription
I recently sold my old house and reset my old arlo pro system and install to the new house, I couldn’t activate my camera and require the paid subscription to use it, I did not pay or subscribe before, why is that? Can I install it without the subscription?
@Jagco wrote:
I recently sold my old house and reset my old arlo pro system and install to the new house, Can I install it without the subscription?
Yes, you should be able to install it w/o a subscription.
It sounds like you are using a new account - is that correct? If so, did you remove the cameras and base from the old account?
FWIW, you could have just moved the equipment and kept on using the old account.
