Can connect only via wifi but not using cellular data. Tried reinstalling app.
  • 2 Replies
  • 1928 Views
jack007
As of Friday I can no longer connect via cellular data.
I either have to find a WiFi connection or wait until I get home.
As a test, I connected at home with no issues. Then I turned the WiFi off on my phone and was unable to connect.
I've tried uninstalling the app but the issue persists.
I've put up with a LOT of issues in the three years I've been using Arlo, but obviously this tops the cake.
Being as I rely on my system to tell me if I have unwanted visitors when I'm away....
I have a Moto Z Force an I hope Arlo isn't going to blame Verizon.
jack007
I got it resolved.
Called Verizon.
Apparently my phone lost synchrony with the system. They reset it and resynched it.
Problem solved.
Maybe this will help someone else with a similar issue? The kicker was when I discovered that my other apps that require internet access had quit connecting out on the road as well. They all worked fine at home with my WiFi.
Are you using a VPN? If so, turn it off.
jack007
I got it resolved.
Called Verizon.
Problem solved.
