As of Friday I can no longer connect via cellular data.
I either have to find a WiFi connection or wait until I get home.
As a test, I connected at home with no issues. Then I turned the WiFi off on my phone and was unable to connect.
I've tried uninstalling the app but the issue persists.
I've put up with a LOT of issues in the three years I've been using Arlo, but obviously this tops the cake.
Being as I rely on my system to tell me if I have unwanted visitors when I'm away....
I have a Moto Z Force an I hope Arlo isn't going to blame Verizon.
I got it resolved.
Called Verizon.
Apparently my phone lost synchrony with the system. They reset it and resynched it.
Problem solved.
Maybe this will help someone else with a similar issue? The kicker was when I discovered that my other apps that require internet access had quit connecting out on the road as well. They all worked fine at home with my WiFi.
Called Verizon.
Problem solved.
Are you using a VPN? If so, turn it off.
I got it resolved.
Called Verizon.
Problem solved.
Called Verizon.
Problem solved.
