Can a guest disable the siren?
  • 2 Replies
  • 1269 Views
spenn
I want to give access to a guest to disable the siren if they trigger it by mistake, but I don't want them to be able to see my full library, or change modes, or disable the system entirely (in case they forget to enable it again).
We run a decent schedule that we've never set off by mistake, but should our house-sitter get home late, intoxicated, and forget that there's a camera pointing directly at the front door which sets off the Siren, I want them to be able to disable it! How do we achieve this?
If they can get access to the base, all they need to do is push the top button to turn off
spenn
Thanks, this could probably work. Our siren is quite high up for obvious reasons but they'll have access to a ladder at least!
