Can I upgrade my base station to view locally stored videos?
I have the Arlo Pro cameras with VMB4000 base station. I bought the doorbell not realizing that it will not record video once your subscription is up after 3 months. I think this is the insane after buying the 4 camera set and spending all this money. It wasn't very clear at all that this would not function the same as the cameras. Oh well. I then decided to go out an buy a external HD to connect to the base station to record locally so I could see the video doorbell. Now I have just found out that you cannot view those locally stored videos in the app unless you have the newer base stations (correct me if I am wrong). So, what are my options here ? Can I just buy an upgraded base station to make this feature work ? Do they sell just the base station ?
Yes, you can purchase either smarthub (VMB5000 or VMB4540). Though standalone VMB4540s are hard to find.
The break-even over a paid single-camera subscription is pretty long.
Well, you can see the videos from a VMB4000 but you must safely eject the drive so you can view them on a computer. The newer bases/hubs can be viewed via the app so no ejection is needed.
Yes, you can buy just a new hub or base. The 4540 and 5000 models are both for sale individually starting at ~$100. A quick Google will get you results to pick from.
