Can Arlo Pro Battery be Charged while Inside the Camera via the microUSB Port?
  • 1 Reply
  • 4720 Views
Retired_Member
Not applicable
Hi,
Just as topic. Will it be possible to charge the batteries via the microUSB port without removing them from the cameras or will they only be able to be charged by taking them out and plugging them with the power adapter?
Thanks.
Yes the Pro battery pack charges while either in the camera via the cameras usb port or by an external charge " tube" that hold 2 packs.
There is no port on the pack itself
