Cameras will not update firmware
Cameras will not update firmware and night vision does not work.
What have you tried so far?
D-rod,
Who is your ISP and what are you download/upload speeds? Do you get any error messages when attempting to update your cameras?
jguerdat wrote:What have you tried so far?
Just tried the download, camera blinks like it is supposed to then just goes back to update available
What are your Internet download and upload speeds as reported by speedtest.net? Have they updated after being left on overnight?
I have the same issue. Just bought another two cameras for my system (I started with two, this would be number 4).
One of the two cameras updated the firmware. The second seemed to try to do it, but then after blinking as it was supposed to for a minute or so, now simply says "update the firmware" and then when I try to do so, it just cycles back to the main screen.
I pulled the batteries, removed the camera, resynched the camera, added it to my account, and tried again.
Twice. Each time the firmware does not update. It just immediately exits without updating anything, but doesn't show me any image on the camera.
Had the same issue. Support asked me to log out of the app and sign back in. Voila the update button disappeared. I went into the camera settings to verify the firmware was the same as the other camera and it was.
I just added two cameras to my system and the second camera kept saying there was an update even tho I chose the update option. Turns out it did update (probably the first time). When I logged out of the Arlo app and closed down my browser (chrome) and then started browser and then logged back in to Arlo app everything was good. Everything was good and the second camera had updated. Hope this helps.
