Cameras Stopped Recording Again
  • 4 Replies
  • 8809 Views
  • 2 Likes
T369
My cameras stopped recording again. I didn’t make any configuration changes on my end. Today I noticed that the cameras would record when it detected motion (as normal). But after they recorded for the duration that I set them to, they won’t record again at the next detected motion. During this time I noticed that the motion icon stayed lit (e.g., amber color) and not return back to gray whatsoever..
Streak2
Master Master
Restart your base and see if that fixes things.
Streak2
Master Master
__Pete__
I have the same problem. Started yesterday after the firmware update. I have eight cameras, and only one appears to be affected. It's also my only CVR camera.
I tried unplugging and re-plugging the base station. Didn't fix it.
I then removed the Camera and re-added it. Still not fixed. It records one video, then the little yellow guy stays on permanently and it doesn't record another.
I just tried unplugging the camera from power, removing the battery for a while, and putting the battery and power back. It powers up, connects, but the little yellow guy comes on and stays on. Didn't record any video.
__Pete__
I think I fixed it.
I had it set to record for the maximum time of 2 minutes on motion. It's worked like that for months without issue. I just changed it to record until motion stops. Now the little yellow guy goes grey again, and the videos get uploaded to the library. It's done 3 videos, so I think it's fixed.
T369
Resetting the base seems to fix the issue, but I wished I knew what caused it after months of running just fine.
