Camera not detecting obvious motion with sensitivity as 100%
Both of my cameras are not detecting obvious motion. This started two weeks ago. Sensitivity is set to 100%. Cameras are 25 feet away from the active area. I reset the modem. It seemed to improve for a few hours. Anyone have any suggestions???
Remember that for people, the motion detect maxs out at about 25 ft.... so your at the max now.
I would reboot the base via the power button, let the system come back online for a min or two and then test.
If NG, ( you said you reset the modem ) I would turn off the base, router, modem and bring them back one at a time ... modem first, then router, then base ( give each time to fully come online )... again test.
If this doesn't solve the issue, then ONE at a time remove the cameras ( remove device ) and bring back as if new... test.
( you will have to change defaults and custom modes if any for each camera )
