Camera does not get any more battery life after using Solar charger
Mr camera after using the Weinstein solar charger does not get any more life out of the battery than before and now the battery won't charge on my wall charger. The camera just flashes an orange light breifly when I plug in the charger
The third party solar panel may not charge properly and drained the battery....
There was an Arlo artilce on this... basicly if the battery get to low, the Original adapter can not start a charge.
Answer is plug in the original adapter/cable let it go about ten mins ...if "lighting bolt" charging not showing then uplug , wait a few mins replug it in...repeat 6x.
This should give enough to allow the battery to charge.
If not contact Arlo
