Camera & Base Station Sync/Doesn't Sync in different network
Hi there,
I purchased the Arlo Pro + Basestation combo to use for office space monitoring.
1. at the office using the office's network, after following the setup procedures, the camera doesn't sync with base station while both of internet + power LED lights are green. I also tested the ethernet cable, it works; I'm able to turn on siren for base station, so base station works.
2. I took the same camera + base station home to test by following the same procedures but using my home network and it works perfectly (camera synced with base station within 10 sec).
3. I went back to the office and used the same set devices, the camera still won't sync with the base station in the office network.
What is the source of this problem? I suspect it is due to the network at my office? If so, how do I fix this issue?
Thanks,
-Yi
Check with your IT person, or DMZ the IP assigned to the base station and sync the cameras.
Hi jcwrks, thanks for the direction. If possible, can you kindly provide more details re. IP assigned and how to do that?
