Camera Light sensitivity - Arlo Pro
  • 1 Reply
  • 4218 Views
RockyTom
 Is there a way of adjusting camera light sensitivity, on camera images are washed out?
there is a small adjustment in the live view as sun icon which will (IIRR) go from +2 to -2 ...it makes some diff but not much
If washed out, it more than likely is due to the IR lights reflecting off something to close..adjust the camera to avoid this ( like a side wall , etc )
