Camara brightness auto-adjustment triggers motion sensor
Every 5-10 minutes the camera re adjust brightness or light contrast and that triggers motion sensor. Any fix?
The cameras don't operate except when motion or sound is detected so brightness changes can't happen. You can see the occasional autoexposure artifact at the very beginning of recordings, showing that the correction happens at that point.
Something else must be triggering the recordings. What are the sensitivity settings in your modes and rules? Post a screenshot of the camera view since it could be a positioning issue.
