Both Pro and Pro 2 are showing "Low temperature, camera must be warm" but only 35F?
Both Arlo Pro and Arlo Pro 2 showing this message “Low Temperature, camera must warm up before you can use” ! Its only 35 degrees F in Illinois!
Usu that will show up if you try to charge the battery around freezing... bad for battery pack.
As to usage tho, it should work to about -4 F
