Battery not charging
Why won't my camera work if the battery won't charge? Power is connected and on and synced. I have multiple cameras and this is the only one not working
- Does it work if you remove the battery (but still connect the charger)?
- Also, have you tried swapping batteries with another camera? Does the problem stay with the camera, or move with the battery?
