Battery not Charging
@Jb27586 wrote:
How can I save the batteries?
There is a process here you could try: https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
That implies there's no connection between the battery and camera or the battery is totally dead. Can you swap batteries between cameras if you have more? Have you checked the battery and camera contacts to be sure they're clean and undamaged?
You don't need to wait a few hours....
plug in to charge and after ten mins if no charging icon shown, unplug and wait 5 mins then plug in again... repeat 6x before thinking the batt is dead. Each time a small bit of charge gets into batt, it needs a min amount to properly start the charge cycle
@TomE ; @jguerdat ; @StephenB Does anyone have any other suggestions for me to get these cameras working? I've been trying to get them charged for over 2 weeks now, and starting to question if they can be saved. Does Arlo provide replacement batteries if this happens? Can I exchange them? I appreciate any assistance.
You said earlier that the cameras hadn't be used for some years. If so, the batteries and cameras are long out of warranty - so Arlo won't exchange them.
But you can purchase Pro batteries. https://www.arlo.com/en-us/accessories/VMA4400-100NAS.html Maybe just get one, and see if that solves your problem.
