Battery Life Has Recently Dropped Significantly for Pro2
  • 1 Reply
  • 1280 Views
mkulin11
We have a few Pros and then the chargeable Ultras. The Pros are now going from 100% to low battery in under 2 days now. I no longer want to use them and there are no firmware updates. I have done everything from moving the Netgear Arlo box farther away from my router to changing battery companies to lowering my video quality settings. I am wondering if this is related to July 1, 2023 EOL and this is a known expectation based on the latest firmware or hardware.
Not related to the EOL stuff. I would try moving a camera closer to your base to see if that helps. If not, there may be a signal strength and/or quality issue with something near the base causing interference. You could try removing the system from your account and set it back up as if new to clear out any weird issues that may have crept into the system.
