Battery 4TW1747B0DCC4
I've had this system for less than week. I've installed it, but one of the batteries is DOA. It will not charge. I do not see any lights on the camera when I try to charge it and it will not sync. I notified Costco, and they will take the whole system back, but it seems kind of silly for me to take everything down, put it in a bag and take it back just for one battery.
The battery should be under warrantee. Is there any way I can get it replaced under warrantee?
PS: no labels apply to this issue.
Contact Netgear Support https://www.arlo.com/en-us/support/contact.aspx
