Base station wifi config?
  • 2 Replies
  • 3305 Views
dookie
Is the private base-to-camera wifi network at all configurable?  I would love to be able to manually set the channel.  If not, do you expect this in future firmware?  I am in a wifi-dense area and the auto channel select seems to make poor choices...
Nope, not configurable in the least.  I expect, but don't know for sure, that it will never change due to the possibility of compromising the security designed into the system. If you have access, it's easier for someone to figure a way around how to make other changes.
As mentioned above...
But the base unit if fairly close to you home wifi will follow the same channel as the home router.... Netgear has stated the two sharing the same channel shouldn't be a problem re collisions. So you can change you router to a clearer channel and reboot the Arlo base... it should follow to the same.
Another work around but not permanent if close to the home router AND the base unit reboots , is to change you router , reboot the base unit to follow and then change your router back to the original channel.... not pretty but it works
