Base station shows connected but when I sign in to my account, it says "Add New Device"
  • 21 Replies
  • 5058 Views
  • 6 In Conversation
Circles25
  • My system, in US, is over a year old so not “entitled” to live help, and I don’t have a subscription. I was willing to purchase one but when I hit purchase button on Arlo’s website, nothing happens. Base station shows connected to internet but when I sign in to my account only screen I get says Add New Device. When I go through that, it ends up as No Arlo Devices Found. How can I get back on-line if I don’t know where the problem is, and no live person at Arlo is willing to help? Can’t get help because I don’t have subscription, but can’t get subscription at Arlo.con because purchase link doesn’t launch. I’m being run in circles
ShayneS
HI @Circles25
I have a member from my support team that will reach out to you to resolve this. Can you PM me with the best time/number with time zone to reach you and I will let him know ASAP.
21 REPLIES 21
What model camera and base?
If you aren't sure, open the camera and remove the battery, and you should find a label.  Look for a VMBxxxx label on the base.
Circles25
The only model No. on battery says A-1B
The box that my cameras and base station came in says Arlo Pro 3 wire free HD Security cameras VMS 4330-100NAS.
Thank you
Circles25
That is:
Arlo Pro,
3 Wire-Free HD Security Cameras VMS 4330
(not Arlo Pro 3)
Dannybear
Look at the bottom of the arlo base station unit for a label starting with the letters VMB to get the model number.
Dannybear
Open the camera battery compartment, remove the battery and look for the label starting with the letters VMC to get the model number.
Circles25
VMB 4000
Circles25
Sorry, I was looking at label on the battery itself, not inside compartment
Battery box says VMC 4030
Base says VMB 4000
Dannybear
What mobile app are you using to purchase a subscription, iOS platform devices will not work so you would need to use a pc web browser to login and purchase via the settings manage subscription page.
Can you tell us what the Base station LEDs are showing?
Circles25
I am using Iphone7, have not used pc since my husband passed in 2018.
Security cameras went off line Weds 10/12. I did hit the reset button on back of base station and that is when problem began. The lights on the base station are solid green for power; solid green for internet connection; Amber for cameras. I have tried syncing the cameras, the blue lights come on for 10 seconds, then the sync fails.
when I sign in to my Arlo account, I cannot get to devices page, just Add Nee Device, which indicates does not recognize device, even though power and internet connection are working.
Dannybear
The base station LEDs status you describe indicates that the base station has been factory reset and is waiting to be claimed by the account.
To claim (Add) the Base station the mobile device with the arlo app installed needs to be connected to the same network that the base station is connected to.
With the mobile device this can be achieved via the local wifi in your router. I.e. the phone needs to be on wifi. connected and not set to use cellular data.
Using the pc is the easiest method if you have one as it can directly Ethernet connect to your router.
Circles25
I know I did not use PC to originally connect to Arlo, I just used my phone. Setting up PC is not an option. Thank you for trying to help, but it’s ridiculous Arlo won’t stand behind their product and with their customers; to make us do multiple messages back & forth, over several days, rather than (hopefully) one phone call to straighten this out. And when I upgrade my phone, I’m guessing I’ll have to go through it all over. I now have $500 of worthless Arlo equipment, and will have to start over with “that other company”.
Dannybear
One option is to get access to a friends pc and purchase a subscription by logging into your account, settings / subscription  / manage subscription.
Once you have a subscription linked to your camera, go to settings / support / your camera to see the support entitlements and see the phone number button.
ShayneS
HI @Circles25
Circles25
Sorry, How do I send a PM to you?
Circles25
Disregard, sent PM to ShayneS
ShayneS
Looks like the issue has been resolved, please let us know if you need any further assistance : )
Circles25
Thank you all for your time & patience 😊
Wiskas50
Same exact issue is happening today for us.  How to resolve?
Vpen69
I’m having the same issue. No devices are found and the station has all 3 lights illuminated in green. I get notifications but nothing is viewable
Circles25
Well…mine was human error. When I tapped on “add new device” on next screen, I was then going into the “Cameras” link (thinking because I had security cameras system) but if I had scrolled down further, there is a “Base Station” link I should have been clicking on and pairing it up through that.
Hope that helps.
Circles25
Hopefully you can see my prior reply to someone else today, and hopefully it helps you.
