Base station offline
  • 2 Replies
  • 1590 Views
Oxypermian
I have read the posts on this and was able to get base station back when I am present, but when the system is at our other home 200 miles away - I am blind until I get back the house. This has happened twice and not having the reliability I expect in Arlo is troublesome. Is there any way to reset remotely?
The base out happens mostly to power outage and then the bootup of devices ( modem router,base ) are not sequenced properly. ( tho you can reboot the base remotely if still online )
The only way to remotely reset the base is via a third party product....
Wemo outlet allows you to turn on/off remotely if there is wifi.
Some have used a wall timer that shut off/on once in 24 hrs.
Oxypermian
Thanks. I will give it a try
