Base station not being discovered
Hi, I’ve had this base station VMB4000 for about 7 years. All of a sudden none of the cameras were showing images. I’ve tried everything I could think of and no resolution. The base station does show up on router device list but the three lights that appear on base station is power solid amber, internet no light, camera no light. I’ve tried connecting to different ports and using different cable and factory reset and still base station cannot be discovered. Is this an internal hardware failure in base station?
The amber power LED says that the base station has not fully booted up.
That could be an issue with the power adapter, so you could do a risk-buy of a compatible replacement. If that doesn't solve it, then the base must have failed.
Thank you for your assistance. Going to buy replacement power cord.
