Base station network physical connection.
  • 4 Replies
  • 11998 Views
Vincent52
Can the Arlo Pro base station be plugged into a hub, or does it have to plug directly into the router?
Like the regular Arlo base, it needs an ethernet cable connection and Internet....
it can be to a switch or router
Vincent52
Ok thanks. All of the directions and videos only show a direct connect to the router so I wasn't sure.
As a PS.... Some have hooked into wifi extenders with Ethernet port to centrally locate the base for max coverage
Vincent52
Good idea and nice to know that would work. Thanks.
