Base station disconnects from the internet
  • 5 Replies
  • 4028 Views
Beesboer
Hi I setup my Arlo Base station and 4 cameras 2 days ago. Since then the base station constantly looses internet connection after about an hour. After pluging the LAN cable out of switch and the back in Internet is active again.
All other computers are not loosing connection so it must be the Arlo base station that is doing something.
Please help
5 REPLIES 5
steve_t
Master Master
What makes you think it's losing its internet connection?
Beesboer
The Internet light on the base station is yellow and on the app it says the base station is offline
steve_t
Master Master
Rather than disconnecting the LAN cable and plugging it back in again, have you tried restarting the base station?
Beesboer
Yes I have restarted the Base station as well, alos tried to restart the router and also restart both at the same time, but problem persists
It could be an issue with either the base or the router.  The amber LED indicates connection to the router but not the servers.  Open a case with support using the Contact Support link at the bottom here.
