Base Station not online after modem reboot
My modem/router had to be reset due to data issues with my server. The lights are green, yet i get the error that its not connected to the server. Do I need to do a hard reset to default values and resync the cameras again?
Possibly, but first remove the power from the base for a few seconds the plug it back up and allow time for the base to boot up. Check it then. If that doesn't do it then I guess you will need to do a factory reset.
Brian
Before a full reset....
I would turn all off and power up in proper order ; modem, router, then base (allow each to come online prior to next )
