Base Station and SanDisk Ultra Fit 128Gb USB Drives?
  • 5 Replies
  • 5562 Views
shipoopi
Any one know if there are any issues with
SanDisk Ultra Fit
USB flash drive - 128 GB - USB 3.0
drives?
The spec on the Pro base / drive  maxs at 2TB  in fat32 format... don't think its usb v3 but a 2
5 REPLIES 5
shipoopi
Thank you, as of right now I'm not looking for 2TB storage but that's definitely helpful for future growth.  I'm looking for something small and compact, ie not a lot of additional stuff hanging off the base station.
I find it interesting they aren't USB 3.0 though (transfer rate)...
2TB is really overkill. I use a 16GB thumb drive which lasts me a few months with and average of 100 videos a day.
USB 3.0 is also overkill due to the file size and data rate needed to store the videos. Note that the base is only 100Mbps for the same reason.
Paul_FCCL
Prodigy
Prodigy
SanDisk Ultra Fit
drives?
I'd be more concerned about the width of the usb connector, can't tell fom the pic wich is the connecting side but I would check for available space in the back of the base station.
There are short USB extension cables for places where a particualr device won't fit (I have some Hauppauge USB TV tuners that came with these).  However, there's no reason to get expensive with a thumb drive for this purpose unless it's for tranfer rates when connected to a computer.
