Base Station LED Indicator
After the recent firmware updates to resolve the battery drain issue, I discovered that my Base Station LED indicator for camera seems dimmer than those for power and internet. Although all is showing green, but it's just weird why one indicator is showing a shade darker than the rest. Anyone have this issue?
Haven't seen that on 3 bases... which model ?
It may just be a weak LED, as long as it working I wouldn't be overly concerned.
OR if less than a year, you could always try for a warranty issue by contacting Arlo Support.
I don't think it's a weak LED as the light returned to same brightness as the other 2 indicators. I suspect the base station maybe communicating with the camera to extract data or something, but it's weird as there is no flickering. Hopefully someone from the Engineering side can shed some light on this phenomenon.
