Bad motion detection Arlo 4Pro
  • 1 Reply
  • 1599 Views
NotHappy7
I have 3 Arlo 4 Pro cameras, this is the second set of 3 cameras. They all do the same thing. Motion is detected and nothing is there. The camera will tell me it's a person, an animal, even a vehicle I go to look and there is nothing in the recording. There is nothing in the video, I do however hear wind!! Although I did not know that wind could be all those things and set the cameras off. I have received over 400 notifications in a day. Its getting old.
I see that this might be an ongoing issue as there is a post from 2017 about the same issue. Can anyone help with this?
This sounds like you have audio detection enabled in your modes and rules. Be sure to verify that it is disabled (unchecked). You may also want to reposition the camera if leaves/branches, etc. are blowing around which can reflect the sun's IR, leading to false triggers. Reducing the motion sensitivity in your modes and rules may also be needed.
