1) How do you change audio sensitivity on the Arlo Pro using IOS? Device settings only gives me the option of setting motion sensitivity.
2) Can I get push notifications for audio using the Arlo Pro? How?
These settings are on a camera by camera basis which means that you adjust these settings in the Rules section of the Mode you are using, (probably the Armed mode) for each camera.
Brian
Brian
