Aro Pro battery cannot charge. Using original cable and charger.
I can’t get the battery of the cameras to be charged. And yes, I am using the charger and cable that came with the camera and it’s not charging.
If the battery is drained to low, the charger can take a number of times to start a proper charge....
read the following;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Try clean up camera charging contact surfaces. If camera is outdoors, these are getting oxidized and camera will not recharge. After you clean them, connect charger and check device settings , you should see the lightning symbol overlay on the battery icon.
