It sounds like the camera failed. It you purchased it less than 12 months ago, then you could contact support and ask for a warranty replacement. https://www.arlo.com/en-us/support/contact.aspx
I am running 4 Arlo Pro cameras and have the same problem with one of them, it is about 15 months old. I switched the battery when it got low and it would not come back online. Watch the light on the front when you put in the battery. Mine blinked blue for about 30 seconds or so then switched to a rapid orange blink for about 5 - 10 seconds then went out completely. It never came back on. I reset the hub and tried hitting they sync button on the camera. Nothing worked. I even tried switching it out with the camera sitting near the hub but that did not work either. I sent an email to support last week, but have not heard anything from them.
