I have had Arlo cameras for years and never paid for a subscription. I have four cameras that were free and I bought the doorbell camera and pay for a subscription for that only. I was grandfathered in for the other four cameras that I have and now they have been disabled from Arlo says I need a paid subscription. I’d like to know why this happened?
This symptom should now be resolved. Are you still experiencing this messaging?
Best answers
We're hearing reports from some users that when attempting to live stream, a subscribe now message is presented. We're currently investigating these reports and will provide more information as it becomes available.
Try removing one of the old cameras from your account, and then add it back. Some users have reported that "add device" is non-responsive. If that happens to you, you can use the manual push-button sync.
The same message about the camera is inactive and requires a paid subscription. Started today. Will try removing and adding them back. This happen to three of the five cameras. Pro-2 cameras.
I have an Arlo pro 2 four camera system with no subscription. It has worked great for several years; however, today it says three of my cameras are inactive and require a subscription. Has something changed?
I'm having similar issues with my Arlo cameras as well. I have been using my Arlo cameras for 3+ years & now all of a sudden the app prompts you to purchase a subscription (No Live Feed or any options available). I have never had to purchase a subscription & I don't care to use any of the extra features. Question: "How do I get my Arlo cameras to Operate Normal like before?" Consumers should Not be forced or tricked into purchasing a subscription. I have no use for a paid subscription. Can I Please get some HELP
I have had 4 cameras for 2 years now. Within the past hour I got a message saying subscription required and they are not working
What cameras do you have?
Did you have a subscription before?
I’ve had my cameras for about 4 yrs working perfectly fine… footage is saved for 7 days if there something important then I’ll download it, I tried the subscription and it SUCKS I was paying for 30 days and that is the only difference… it was a waste of money so I cancelled… last month, I noticed they automatically gave me a “trial” which I didn’t request now the trial is over all of my cameras stopped working and they are forcing me to get a subscription which I WILL NEVER… its not worth a penny, I want my cameras back to the way it was before they started this free trial games!
I have 4 arlo pro's. I have never had a subscription before
You posted in the Pro 4 area. The 7-day cloud storage was never sold with the Pro 4 - Arlo stopped offering it on new camera models back in 2018. So you must have a different camera model - likely a Pro 2. If you want to check, try opening the camera, and remove the battery. There is a label inside. It is best to post in the correct forum area, as you will often get incorrect advice if people think you have a different camera model.
Your issue is caused by a bug in the Arlo cloud that affects some legacy camera users.
I am tagging the mods - @BrookeN , @ShayneS , @JamesC . They can do a back-end sync for you that should resolve the problem. One of them will reply here after they've done that.
If you don't want to wait, you can try removing one camera from the account, and then adding it back. That should trigger the same back-end sync. If "add device" is non-reponsive, you can use the manual push-button sync method to add the camera back.
Thx.
There is a bug in the Arlo Cloud that has affected some users.
The mods - @BrookeN , @ShayneS , @JamesC - can do a back-end sync that should resolve it. One of them will reply here after they've done that for you.
If you don't want to wait, you can try removing one camera from the account, and then add it back. That should trigger the same sync (and should resolve it for all your cameras). If "add device" doesn't respond (another bug some folks have run into), you can use the push-button sync method to add the camera back.
Thank you so much! I will await their response. Thank you!
Do you have anything activated in your account, such as activity zones, that require a subscription? If so, remove those settings to see if that helps.
No, I don’t
I have had Arlo Pro cameras for about 10 years that operated perfectly on my local storage hub. A week or so ago, Arlo started a trial feature showing vehicles, people or animals, and that it would terminate in a certain number of days. I was not interested in the service trial and did not subscribe to the service knowing it would end in a few days. However, at the end of the trial, my cameras became inactive and to activate them again they are requiring me to subscribe to their online service. The reason I purchased Arlo in the first place was because it had no subscription and storage was on my local hub. Is anyone else having the same problem?
Arlo is still providing the free 7-day cloud storage for the camera models that were sold with that feature.
Try removing one camera from the account, and then add it back. See if that resolves the issue.
Why does my camera say need a subscription to activate when it’s been working for years without one
just spent an hour on chat with this problem after which I was told it was "a known issue"
why am i not able to see my cameras after six years? Now my camera all flash the same error message in the subject field. They were working just fine then all of a sudden, I get the error message. Anyone else getting the same thing?
I deleted 1 Pro2 then reinstalled it back on my vmb4000 and I could see it on the feed. So I just re-sync my other 3 cameras and they all show on my feed. I'm still working on the dashboard because I only see one camera. Thanks for the help.
Arlo needs to review their policies, especially the way they treat their long time loyal clients and consider the value of customer loyalty / retention.
Thank you very much for your help. I removed and reinstalled one camera and it worked! Thank you!
@yuujh wrote:
I’ve had my Arlo cameras for 5 ish years always using them for free, then was prompted to do the Arlo secure “trial”. Now that the trial is over Arlo is requiring me to upgrade to a package.
They didn't take away the 7-day storage for the camera models that were sold with that feature.
This could be a glitch with the rollout of the new subscription plans. Though there is a bug in the Arlo cloud that sometimes affects this. The mods - @BrookeN , @ShayneS , @JamesC - can do a back end sync to resolve it. They'll reply here when they do that.
If you are in a rush, you can also try removing one camera from the account, and then adding it back. That should trigger the same sync process.
You posted in the Pro 4 area of the forum. That camera model was launched in 2020, not 2018. And that model was not sold with free 7-day cloud storage, so it does require a subscription for cloud storage?
Can you let us know the camera model(s) you actually have?
Is this still an issue? I've seen a few other similar posts that may indicate something changed in the Arlo backend servers.
My cameras are not working and it’s says I need a subscription
