Arlo pro will not obey no notification instruction
One camera will not respond ro set up for no notification. Still get text everytime there's motion. Called Arlo and they said they could fix problem for $139.95.
All other cameras work perfectly , as well as this one. the only thing is I keep getting the text messages that there's motion.
Must be a simple fix. What is it?
I think you called someone other than Arlo/Netgear. Make sure you use the Contact Support link at the bottom of these pages, not from a web search.
Have you checked your modes? If so, have you made sure to save at each step where its available as you back out?
