  • 2 Replies
  • 1497 Views
hsulliva1
Hi. I was once able to change my cameras video length. ... now I can't find where to do it. It is very strange and frustrating. Any one have any ideas? Thanks
JoeCymru
Virtuoso
Virtuoso
You do it through the modes. Choose a mode you want to change the recording time > choose device in the mode > see "motion detected" option and select the caret > which takes you to the next level down and then choose the radio buttom to select either until motion ends or to set a specific time for that device in that particular mode.
Streak2
Master Master
You do it under the mode setting.
Once set don't forget to save.
https://kb.arlo.com/1079027/How-do-I-adjust-Arlo-video-recording-length
