Arlo pro recording sporadically
  • 1 Reply
  • 715 Views
mjbarlo
Hi, I have a set of three arlo pros. Sometimes the alerts & recordings start when a
moving object (daytime person or nighttime raccoon) is already in the center of the frame.
Not sure why I don't get a recording when the moving object enters the frame? Wifi signal is
typically good, and objects are less than the 20-25ft max distance...any ideas? Thank you.
Size of the objects like racoon do make a diff... esp since the max range is prob based on people size
