After recharging camera doesnt connect to hub. Camera doesn’t reset (15 sec reset on sync button) and only does the blink once-twice. Changed battery to one that works
This happens to often. Really regretting spending several thousand dollars on this
The reset procedure for newer cameras doesn't work on the Pro. The only "reset" you can do is to reinsert the battery and/or remove and resync the camera.
As a PS... on battery change, if within range of the base, the camera should auto resync.
With a sync of camera, it in NOT a hold the sync button... only a quick press is done on the base and then camera
Repeatedly repeating removing the battery fixed it after a while. Frustrating but worked
