Arlo pro cameras offline
The camera's says its offline but the base lights are all green, how do I get my cameras to work
Open the battery door, pull and replace battery to reset camera ... it should auto resync ( if not do so )
Bought the 4arlo pro wireless camera system just a few days ago and 3 of the cameras are doing great,but 1 of them keeps going off line.It is very frustrating.Cannot get support to answer me back and tell me my problem.Done everything I know to do.Any suggestions.
Have you tried moving the camera that keeps going off line to a different location? Obviously you tried doing a battery swap with another camera and see if that camera has any issues? If that still doesnt work have you tried re-syncing the camera to the base and moving the camera that is going offline to a different location?
